We recently had a plumber do some work on slow draining toilets. He power rodded the lines and added muriatic acid. We now have a hole in the copper drain line just below an elbow.
Muriatic acid cannot do much damage if it is only there for a moment or two. However, if it says there overnight you can expect some thinning of the pipe wall. What probably has happened to your copper happened to my kitchen drain a few years ago. It is called microbial corrosion, a combination of organics degrading into a very aggressive environment for copper.
You have your own question or want to add your opinion please send a note to our
