Module Six of CCE 281 Corrosion: Impact, Principles, and Practical Solutions
Deposition Corrosion
Deposition corrosion is a subtle form of galvanic cell that can produce pitting in a liquid environment when a more cathodic metal is plated out of solution onto a metal surface. For example, soft water passing through a copper water pipe will accumulate some copper ions. If water is then admitted to a galvanized or aluminum vessel, particles of metallic copper will plate out, i.e. deposit on the surface and stimulate pitting by local cell action.
This plating out action, or deposition corrosion, may be an important factor in the corrosion of the more reactive metals near the top of the series, e.g. magnesium, zinc, and aluminum, when these latter metals come into contact with solutions containing ions of metals (particularly copper) lower in the series. Copper ions in concentrations less than one part per million have been observed to have a significant effect on the corrosion of aluminum by water. Metals, such as copper, that can aggravate corrosion of aluminum are sometimes referred to as "heavy metals in solution. The fact that they are heavier than aluminum is less significant than that they occupy a position lowers than aluminum in the electromotive or galvanic series.
(previous)Page 12 of 23(next)
