Cathodic ProcessesWhen hydrogen ions are reduced to their atomic form they often combine, as shown earlier, to produce hydrogen gas through reaction with electrons at a cathodic surface. This reduction of hydrogen ions at a cathodic surface will disturb the balance between the acidic hydrogen (H+) ions and the alkaline hydroxyl (OH-) ions and make the solution less acidic or more alkaline or basic in this region. In neutral waters the anodic corrosion of some metals like aluminum, zinc, or magnesium, develops enough energy to split water directly as illustrated in the following Figure and equation. (reference)
Electrochemical reactions occurring during the corrosion of magnesium in neutral water The change in the concentration of hydrogen ions or increase in hydroxyl ions can be shown by the use of pH indicators which change color and thus can serve to demonstrate and locate the existence of surfaces on which the cathodic reactions in corrosion are taking place. There are several other cathodic reactions encountered during the corrosion of metals. These are listed below. Oxygen Reduction
Hydrogen ion reduction, or hydrogen evolution, has already been discussed. This is the cathodic reaction that occurs during corrosion in acids. Oxygen reduction is a very common cathodic reaction, since oxygen is present in the atmosphere and in solutions exposed to the atmosphere. Although less common, metal ion reduction and metal deposition, can cause severe corrosion problems in special situations. One particular case worth mentioning here is the plating of copper ions, produced upstream in a water circuit, on the internal aluminum surface of a radiator, for example. The plated nodules, which may form even at even at very low concentrations of copper ions, tend to be dispersed and are thus a good catalyst for the subsequent reduction of dissolved oxygen. It is therefore highly recommended to avoid using copper tubing in a water circuit where aluminum is also present. Such deposition corrosion can be avoided by preventing the pick-up of cathodic ions that will enter the equipment, or by scavenging them by passing the contaminated product through a tower packed with more anodic metal turnings on which the ions can deposit.
Method for removing troublesome ions from solution. a) Heavy metal trap: solutions containing copper ions enter barrel filled with aluminum shavings; b) Waster section: aluminum clad pipe inserted in a system removes heavy metal ions. The section is replaced once corroded. Note that all of the above reactions are similar in one respect; they consume electrons. All corrosion reactions are simply combinations of one or more of the above cathodic reactions, together with an anodic reaction. Thus, almost every case of aqueous corrosion can be reduced to these equations, either singly or in combination. Consider the corrosion of zinc by water or moist air. By multiplying the zinc oxidation reaction by 2 and summing this with the oxygen reduction reaction, one obtains the following equation.
The products of this reaction are Zn2+ and OH-, which immediately react to form insoluble Zn(OH)2. Likewise, the corrosion of zinc by copper sulfate described in the following equation is merely the summation of the oxidation reaction for zinc and the metal deposition reaction involving Cu (II) ions.
During corrosion, more than one oxidation and one reduction reaction may occur. For example, during the corrosion of an alloy, its component metal atoms go into solution as their respective ions. Thus, during the corrosion of a chromium-iron alloy, both chromium and iron are oxidized. Also, more than one cathodic reaction can occur on the surface of a metal. Consider the corrosion of zinc in a hydrochloric acid solution containing dissolved oxygen. Two cathodic reactions are possible: the evolution of hydrogen and the reduction of oxygen. Since there are two cathodic reactions or processes which consume electrons, the overall corrosion rate of zinc is increased. Thus, acid solutions which either contain dissolved oxygen or are exposed to air are generally more corrosive than air-free acids.
Electrochemical reactions occurring during the corrosion of zinc in aerated hydrochloric acid Therefore, removing oxygen from acid solutions will often make these solutions less corrosive. This is a common method for reducing the corrosivity of many environments. Oxygen removal may be accomplished by either chemical or mechanical means. If a piece of mild steel is placed in a solution of hydrochloric acid, a vigorous formation of hydrogen bubbles is observed. Under such conditions, the metal corrodes very quickly. The dissolution of the metal occurs only at anodic surfaces. The hydrogen bubbles form only at the cathodic surfaces, even though it may appear they come from the entire surface of the metal rather than at well-defined cathodic areas. The anodic and cathodic areas may shift from time to time so as to give the appearance of uniform corrosion. If this action could be seen through a suitable microscope, many tiny anodic and cathodic areas would be observed shifting around on the surface of the metal. These areas, however, are often so small as to be invisible and so numerous as to be almost inseparable.
