Temperature rise (NASA)
Corrosion Test Results - 120 hours
See the back side
This page describes the results of a very expedient combination test designed to reveal the GOOD, the BAD, and the UGLY in the commercially available corrosion prevention compounds listed here.
In a recent experiment carried out by the Corrosion Doctors, a modified atmospheric corrosion coupon (CLIMAT) was also used in an intermittent testing regime to rank the corrosion inhibitive efficiency of corrosion preventive compounds (CPCs). Please stay tuned if you are interested to obtain a report detailing the analysis of the results produced during that test and two completely different tests made with the same CPCs. This report will be available shortly, but it will not be free!
