Corrosion Forms through Examples
“It is convenient to classify corrosion by the forms in which it manifests itself, the basis for this classification being the appearance of the corroded metal. Each form can be identified by mere visual observation. In most cases the naked eye is sufficient, but sometimes magnification is helpful or required. Valuable information for the solution of a corrosion problem can often be obtained through careful observation of the corroded test specimens or failed equipment.”
Is this a quotation from the last edition of CORROSION BASICS?
As written somewhere else on the Corrosion Doctors Web site, if one picture is worth one thousand words, one thousand pictures is worth ONE MILLION WORDS!! Well, we are not far from there yet! The main goal of the following list will be to introduce our continuously growing number of visitors to the many facets and forms of corrosion.
A useful picture is missing and you have it in your files, please send it with an explanation note to our
Anywhere and anytime you can also search the Corrosion Doctors Web site with Google that has catalogued most pages and words the site contains.
Google
Search WWW Search Corrosion Doctors
